Pangear's avatar
Pangear
XAV1601v2 with Netgear Powerline Utility 3.1.0.4
There was  discussed in past a lot about Netgear's Powerline Utility 3.1.0.4, the utility does not allow to detect powerline adapters and  was recommended to use instead either Netgear Genie or ZyXel utilities.
Has been there any response from Netgear's support engineering the actual reasoning for this utility to fail ?
I do not think that Netgear's Genie 2.2.27.1 allows to twick QoS parameter in powerline adapter configuration.
  • michaelkenward's avatar
    michaelkenward
    No.
    Probably because there is nothing to tweak. Powerline is just a "cable". It does no signal processing and therefore you cannot use it to control QoS.
    By the way, you have posted your message in the section of this community given over to the Nighthawk App. (This is easily done, given Netgear's impenetrable community structure.)
    If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
    Powerline Networking - NETGEAR Communities
    • Pangear's avatar
      Pangear
      I guess, you are familiar with "XAV1601 Powerline AV+200-nano User Manual". Please read the chapter 2 about available tweaking parameters on this device using Netgear Powerline Utility before responding.
      Thanks
        michaelkenward
        That is a seriously old (2011) AV200 plug. I am surprised that there are any still in use.
        Netgear has not produced a Powerline utility for any recent plugs. Nor do newer plugs support QoS.
        If you want to use that AV200 plug, then either get the original utility or see if the ZyXel alternative works. That supports features that Netgear's "newest" utility does not handle. For example, it can disable Standby mode. It also suppports something called "Priority".
  • Does Powerline Utility 3.1.0.4 work ? I doubt, probably it was indended for early versions of Windows, like XP.
    I think similiar utilities use Winpcap utility dealing with Ethernet packets. The old Winpcap 4.1.3 was upgraded to Win10Pcap based on
    WinCAP organization. Does Netgear include those upgrades in their products, I have no idea.
    Also, I noted that on one PC cannot be installed both NetgearGenie and Netgear Powerline Utility since they use common files
    like packet.dll and winpacket.dll.
    My observations are Netgear Genie can find on network my powerline devices but Powerline Utility cannot while I use Windows 10 OS
    Regards to all
      michaelkenward
      It does here. See above.
      64-bit Windows 10, several PCs.
      Maybe you don't believe my screenshots and detailed description.
      That is not my experience, or my observations (see above). Then again, not sure that if follow "find on network my powerline devices".
      • Pangear's avatar
        Pangear
        Michael,
        I do not know what is unique in your connection vs. mine. My PC with WIN 10 32-bit OS is connected to XAV1601 and Netgear Router R6250  is connected in turn  remotely to other XAV1601, the router is connected to Cable Modem. So, I  have a reliable connection to Internet web with average speed +
        50 Mbps.
        However, Powerline Utilty when it is brought up cannot see any powerline devices ( I have four ). NetgearGenie works without problems.
