d_rick
Dec 21, 2013Tutor
XAV5101 - QOS setting to align with rest of network
curious what the optimal QOS setting would be on this side of the network to line up with the rest of the QOS setttings: these units support VLAN tag and TOS field, i assume i should enable them bo...
jmizoguchi
Dec 22, 2013Virtuoso
I don't think VLAN tag would associate with router. You may able to prioritize the LAN ports on router side , switch while you can keep using the QoS separate so that devie behind the power line works within that device
