FragrantBeauty
Sep 18, 2012Aspirant
XAV5101 Not Connecting Consistently
I'm using a XAV5101 Powerline Adapter set in a simple straight forward setup, but I'm consistently having problems getting it to connect. I'm going from a Linksys WRT54G router to an adapter right be...
lionheart12
Well, I am in a similar bind. My connection is stable for a few hours, then the connection drops for no reason. The led lights are all green when that happens. Each adapter can communicate with each other, but the adapter connected to the router seems to lose connection to the router itself leading me to believe the internet was down, which it was not.
I am also contemplating a return if there is no solution. Its just too much of a coincidence for this problem to occur to other people. Just read the amazon reviews.
