FragrantBeauty
Sep 18, 2012Aspirant
XAV5101 Not Connecting Consistently
I'm using a XAV5101 Powerline Adapter set in a simple straight forward setup, but I'm consistently having problems getting it to connect. I'm going from a Linksys WRT54G router to an adapter right be...
FragrantBeauty
Sep 19, 2012Aspirant
I spent a lot of time troubleshooting this problem. I tried moving the adapters to different plugs, doing multiple factory resets and pairing the adapters using the buttons and utility software, and I could never get them to work consistently with my WDTV Live Hub, which by the way works fine using my WiFi via Linksys router.
