FragrantBeauty
Sep 18, 2012Aspirant
XAV5101 Not Connecting Consistently
I'm using a XAV5101 Powerline Adapter set in a simple straight forward setup, but I'm consistently having problems getting it to connect. I'm going from a Linksys WRT54G router to an adapter right be...
FragrantBeauty
Sep 25, 2012Aspirant
I've contacted Netgear tech support and they are having run the same tests I've already done. My current test:
I put both powerline adapters in the same room in adjacent outlets about 5 feet apart. I pushed the reset button on both adapters, then after they were reset, I pushed the security buttons on both. The lights went green. I connected my laptop and it got a connection. I ran the Netgear Powerline Utility and it reported that both adapters were connected at 460MBPS and that the security was set. My laptop stayed connected for a couple hours, then disconnected again. It did not reconnect.
