FragrantBeauty
Sep 18, 2012Aspirant
XAV5101 Not Connecting Consistently
I'm using a XAV5101 Powerline Adapter set in a simple straight forward setup, but I'm consistently having problems getting it to connect. I'm going from a Linksys WRT54G router to an adapter right be...
Simonch
Oct 13, 2012Aspirant
lionheart12 wrote: Well, I am in a similar bind. My connection is stable for a few hours, then the connection drops for no reason. The led lights are all green when that happens. Each adapter can communicate with each other, but the adapter connected to the router seems to lose connection to the router itself leading me to believe the internet was down, which it was not.
I have run into exactly the same situation. :(
At most of the times the connection would be restored automatically after several minutes.
