SriniK
May 29, 2021Aspirant
XAV5201 + XWN5001 Speed
My connection is as below:
LAN port2 of WNDR4700 (speed here is about 200mbps) > XAV5201 --- powerline ---- XWN5001.
Both powerline adapters are in the same room on the same electrical circuit. Connected laptop wired on xwn5001. The o/p speed is hardly 50mbps. Even when xwn5001 is plugged in a distant room, the speed is the same.
firmware version on all WNDR4700, XAV5201, XWN5001 are all latest.
why is the speed this low?
I'm not sure that I understand what you are asking about here. Something to do with the Ethernet speed of your laptop?
Regardless of their alleged plug-to-plug seeds, LAN ports on the XWN5001 plugs are limited to 100 Mbps. Any talk of 200 Mbps anywhere else in the network is, therefore, irrelevant.
Even 100 Mbps is one of those theoretical measurements that has to cope with local circumstances and two-way traffic.
Newer powerline plugs have 1000 Mbps on their LAN ports.
The WNDR4700 dates back to 2012, so it too will not have the latest technology.
- SriniKAspirant
Thanks michaelkenward.
You mentioned: "Regardless of their alleged plug-to-plug seeds, LAN ports on the XWN5001 plugs are limited to 100 Mbps. Any talk of 200 Mbps anywhere else in the network is, therefore, irrelevant. Even 100 Mbps is one of those theoretical measurements that has to cope with local circumstances and two-way traffic."
Below is what User Manual on Netgear product page says:
on page 7/48:
Powerline LED
• Solid. The device is connected to a Powerline network.
• Off. The device has not found any other compatible Powerline devices using the same
encryption key or has been turned off through the NETGEAR genie.
The Pick A Plug feature lets you pick the electrical outlet with the fastest link rate, indicated by
the color displayed by the LED:
Green. Link rate > 80 Mbps (Best) Good for HD videoAmber. Link rate > 50 < 80 Mbps (Better) Good for SD video
Red. Link rate < 50 Mbps (Good) Good for data
on page 41/48 : Technical specifications:
Data transfer rate Up to 200 Mbps with real throughput greater than 80 Mbps
The light on my device is always Solid green and I never get more than 60mbps. From the above I should atleast get 80mbps.
You mentioned:
Today I bought a "NETGEAR PowerLine AV2 1200Mbps Adapter Kit with Filtered Power Socket Pass-Through" and all I could see was a increase of speed upto 80mbps.
The powerline adapters are after this WNDR4700, so the age of the router or its technology should not matter for powerline adapters' performance.
Do not confuse "link rate" with "Data transfer rate".
Link Rate and Transfer Speed | Answer | NETGEAR Support
