TheBeO
Sep 11, 2011Novice
XAV5501 problem after PC standby
Hi, I've just bought a XAVB5501 pack, with 2x XAV5501. I plugged one near my cablebox, and the other one in my bedroom to a Desktop PC (let give the name PC1, that runs Seven 64x). It works fine, c...
TheBeO
Sep 13, 2011Novice
jmizoguchi wrote: you need change power management on on network adapter.. standby, sleep, hibernation mode always causes erratic issues
thanks jmizoguchi, I knew that, but I tried every option on my network card, and still a problem. What I have on adapter option:
- ethernet energy efficient (translated from french, it talks about setting a economic ethernet mode) -> turn off
- reduce the link speed in standby mode -> turn off
- reduce the link speed when the system is idle -> turn off
- wake on LAN -> turn on
any others ideas? Do you think my XAV could have a problem? (it's a brand new one, I can contact my reseller to change it I guess).
@parksjw: you connect your iPad to the XAV???? With a rj45 wire?? that looks weird for me:confused:
