TheBeO
Sep 11, 2011Novice
XAV5501 problem after PC standby
Hi, I've just bought a XAVB5501 pack, with 2x XAV5501. I plugged one near my cablebox, and the other one in my bedroom to a Desktop PC (let give the name PC1, that runs Seven 64x). It works fine, c...
TheBeO
Sep 14, 2011Novice
Yes it goes to standby, and that's a normal behavior.
I do not know which setting I changed for my latest try, but I think it works. The last two times I put my PC on standby, and wake up few hours after, the XAV was properly awake. I'll wait a bit to see if it works well all the time, I'll keep you informed.
Anyway thank you for your support.
