vidapura
Oct 15, 2019Tutor
XAV5601 compatible wifi repeater/extender
Hi, I have a pair of XAV5601 powerline adapters and they work great. Just wondering if I could add something similar in another room but with wifi connection instead of ethernet. The wifi signal i...
- Oct 16, 2019
vidapura
Oct 15, 2019Tutor
Thank you,
Just to be sure , all of those are compatible with the existing XAV5601 setup I already have yah?
Thanks
Oct 15, 2019Guru - Experienced User
From what I could find, xav5601 is a homeplug AV device. Homeplug av is compatible with Homeplug AV and AV2. They will operate at the slowest devices speed though. The XWNB5602 is a homeplug AV device as well from its spec sheet.
- vidapuraOct 16, 2019Tutor
Ahh ok, so Homeplug AV is a standard?
Great. Thats very helpful cos the device I want to use with the wifi doesn't support N.
Its only 802.11g .. so now I have more options.
Thank you very much!
