paulc01
Feb 14, 2012Novice
XAVB2501 expansion required ?
My current set up is the use of a pair of XAVB2501 ultra adapters and all is working well. What i would like to do though is connect more devices in the remote room, i dont really want to use a hub ...
StratmanX
Feb 14, 2012Tutor
If you already have an XAVB2501 in your remote room why not get an inexpensive switch? You can get a switch with several ports available and they can be either 10/100 Mbps or Gigabit depending on your throughput needs.
