Trenzer
Apr 01, 2012Follower
XAVB5601 problems
1. Why is there no support page for the XAV5601 (or the 2-kit, XAVB5601)?? 2. Just installed this kit. Speeds are good, connection is made around 350 Mbps according to the Powerline utility. BUT, ...
Graham_C
Feb 21, 2016Aspirant
Still no update :manmad:
- JamesGLFeb 23, 2016NETGEAR Employee Retired
Hi All,
I am still waiting for the feedback. I will keep you posted for any updates.
- JamesGLMay 10, 2016NETGEAR Employee Retired
Hi All,
I apologies for the long wait. When a new XAV5601 firmware is available, a firmware upgrade tool will be posted on the NETGEAR website.
- Patator100May 11, 2016Aspirant
Thanks for your update
What a pity that Netgear has not done anything...maybe some others, as I did, have moved to another brand, ie Devolo
My couple of adapters are well stored...waiting for a sign of good will from Netgear to come back to life
- Graham_CMay 12, 2016Aspirant
Hey James,
What about the fact the current firmware link points to the wrong file.
It downloads firmware for the 5501?
cheers
graham
- JamesGLMay 16, 2016NETGEAR Employee Retired
Hi Graham_C,
That was previously uploaded and should be removed since it is not for the XAV5601.
