Trenzer
Apr 01, 2012Follower
XAVB5601 problems
1. Why is there no support page for the XAV5601 (or the 2-kit, XAVB5601)?? 2. Just installed this kit. Speeds are good, connection is made around 350 Mbps according to the Powerline utility. BUT, ...
antonis_mandila
Jul 08, 2012Aspirant
Unfortunately I have exactly the same issue. Although the connection seems to be in good status, green light switched on on both adapters, the connection drops every now and then.
Without something changing on the status lights of the adapters. The drops lasts for some seconds and then the connection is up again.
Something should be done about this!
