Trenzer
Apr 01, 2012Follower
XAVB5601 problems
1. Why is there no support page for the XAV5601 (or the 2-kit, XAVB5601)?? 2. Just installed this kit. Speeds are good, connection is made around 350 Mbps according to the Powerline utility. BUT, ...
StratmanX
Jul 08, 2012Tutor
These are the vagaries of Powerline homeplugs. You will not know how well they will perform, including in sustained function, until you try them. Also, do not believe what the utility says. It has been reported that no Powerline company's utility is factual, ie they all overstate the true extent of function.
Go to Smallnetbuilder.com and search on Powerline or Homeplug for very informational review articles and forum posts including troubleshooting tips.
