Trenzer
Apr 01, 2012Follower
XAVB5601 problems
1. Why is there no support page for the XAV5601 (or the 2-kit, XAVB5601)?? 2. Just installed this kit. Speeds are good, connection is made around 350 Mbps according to the Powerline utility. BUT, ...
Bemorph
Mar 31, 2013Aspirant
Dogbert wrote: Hi All,
One of the engineers asked me to ask if the problem still persists with the latest firmware on the units. Can you post what firmware you are using, and I can pass it on to the product engineer.
Hi,
Yes, the problem is still present. There is still random signal loss.
My firmware versions are:
Powerline adapter 1: V0.2.0.6.CE
Powerline adapter 2: V0.2.0.6.CE
When I try "Check for Updates" in the "Netgear Powerline Utility D.3.1.0.4" it says this: "ERROR: Could not read control file on NETGEAR server."
Followed by: "ERROR: Could not connect to the NETGEAR server."
I do have a working internet connection.
