Trenzer
Apr 01, 2012Follower
XAVB5601 problems
1. Why is there no support page for the XAV5601 (or the 2-kit, XAVB5601)?? 2. Just installed this kit. Speeds are good, connection is made around 350 Mbps according to the Powerline utility. BUT, ...
TKA
Jun 12, 2013Aspirant
TKA wrote: I've got this problem as well. I thought I got it solved with Netgear support (changed cable and router port), but it seems the "fix" only lasted the weekend. Beats me why the weekend was trouble-free, but if that issue with the door vibrations is real, then I can see how a weekend might be more peaceful in this apartment building.
PS. I bet that weekend was trouble-free because I don't read e-mail on weekends. I have three accounts in Thunderbird that use three different IMAP4 servers and three different SMTP servers, all password-protected with SSL security enabled.
