Trenzer
Apr 01, 2012Follower
XAVB5601 problems
1. Why is there no support page for the XAV5601 (or the 2-kit, XAVB5601)?? 2. Just installed this kit. Speeds are good, connection is made around 350 Mbps according to the Powerline utility. BUT, ...
Bemorph
Aug 10, 2013Aspirant
Hi,
Still seeing issues, I have now reported this issue to Netgear.
My reference number is 21685411.
I recommend all of you to also report your issues it's easy! Also refer them here and also to my reference number. There is power in numbers!
http://support.netgear.com/general/contact/default.aspx Just choose email and be prepared to enter the serial number on the backside of the unit.
Best regards,
Bemorph
Best regards,
Bemorph
