Trenzer
Apr 01, 2012Follower
XAVB5601 problems
1. Why is there no support page for the XAV5601 (or the 2-kit, XAVB5601)?? 2. Just installed this kit. Speeds are good, connection is made around 350 Mbps according to the Powerline utility. BUT, ...
benmmellor
Aug 19, 2013Novice
Just borrowed a set of TP-Link homeplugs from my brother in law. Tested in the same sockets over the same 'infrastructure' and not one dropped packet!
It's definitely the plugs that are the issue! My house is only 10yrs old and the wiring was checked by my 'sparky' when having additional sockets fitted to some rooms. No issues found.
Maybe they just need to change the code to remove the 'sleep' mode!
