Trenzer
Apr 01, 2012Follower
XAVB5601 problems
1. Why is there no support page for the XAV5601 (or the 2-kit, XAVB5601)?? 2. Just installed this kit. Speeds are good, connection is made around 350 Mbps according to the Powerline utility. BUT, ...
begad
Aug 28, 2013Novice
Right so swapping the plugs didnt work but it did help indentify which plug was faulty so I have returned the faulty plug for a XAVB5501...hopefully it will work :)
