Trenzer
Apr 01, 2012Follower
XAVB5601 problems
1. Why is there no support page for the XAV5601 (or the 2-kit, XAVB5601)?? 2. Just installed this kit. Speeds are good, connection is made around 350 Mbps according to the Powerline utility. BUT, ...
Bemorph
Aug 21, 2014Aspirant
Bemorph wrote: I might have found a solution to the problem. Open the powerline software, click (or was ir right click?) on the icon for the powerplugs in the upper left corner. Choose Quality of Service (QoS) uncheck "VLAN tags" apply changes.
This seems to have worked for me but still to early to say anything conclusive. I'll post back in a week or earlier if any problems occur.
Issues are back... Sorry for crying wolf. I wish someone from Netgear could have taken a look at this.
- Patator100Nov 30, 2015Aspirant
Hello all
I do also have exactly the same issues as all of you.
I have 2 of these adapters, same issue.
When I replace the adaptapers, on the same power socket (I've tried other socket also), with one of Devolo AV500+ or Netgear XAV5501, no issue at all.
Have you found a solution to fix these consistent drops ?
I found a link to dowload the firmware, but the Neatgear team "forgot" to attach the file in the page !
XAV5601 Firmware Upgrade Utility 2.0.0.0:
http://kb.netgear.com/app/answers/detail/a_id/22061
thanks
- JamesGLDec 01, 2015NETGEAR Employee Retired
Hi Patator100,
You may check the page of XAV5601 for the utility. If it works well with other powerline, it might be the device is defective. You may check the store for replacement or check with support team if your device is still within warranty.
http://downloadcenter.netgear.com/en/product/XAV5601#searchResults
- Patator100Dec 01, 2015Aspirant
Hello
thanks for your feedback
The device is not under warranty anymore.
I have already installed the powerline utility software V3.1.0.4 but I don't see how it can help me to upgrade the firmware or fix my issue.
On other forums, many people seem to have the same issue but none has found an issue nor an updated firmware.
Would it be possible to use the XAV5602 firmware instead ? There is an update/tool available : http://support.netgear.com/product/XAV5602
thanks for helping
