jmartinezclark
Jun 05, 2012Novice
XAVN2001 amber power light. Drops connection.
Hello! I own a NETGEAR Powerline AV 200 Wireless-N Extender Kit (XAVNB2001). This kit consists of a 1) Powerline AV 200 Wireless-N Extender (XAVN2001); and a 2) Powerline AV 200 Ultra Adapter (XAV2001...
dickie
Jun 16, 2012Novice
It could just be that something else on the power circuit is causing noise which results it in working for a while, but then the distortion makes the signal unusable (unplugging the unit resets the frequency negotiation process between the units which allows it to try and handle any noise).
You've tried other outlets, so now you have to try and identify if theres something else making noise on the line (mine was actually the power adapter for my WNDR3700 router).
1) Install the Powerline utility on a laptop / computer
2) Unplug / plug in both adapters and see what the line rate is between them
3) Try removing close by electrical items (including the router) and see if that affects the ability for the connection to stay up, and to a lesser extent the line rate
My powerlines worked find until I moved them to the same room as my router. Then I had to plug things into a power strip with surge protector / PLC (powerline compatible) sockets and everything worked out fine.
