anap
May 03, 2012Follower
XAVN2001 connected to ADB P.DG A4001N
I have a new wifi router from Telefonica ADB P.DG A4001 in my second floor. I need to extend wifi in the first floor and connect my TV-decod to internet using PLC. I cannot connect PLC directly to th...
RobbieOax
May 13, 2012Aspirant
if you have powerline link issues, does not matter which adapter you conect to the gateway...
You can try other solution to connect to TV set as wifi range extender as WN2000RP, WN3000RP, or WN2500RP, which they all have ethernet interface or even use the wifi adapater, you might have to add a dual band router to you gateway and get away from 2.4Ghz interference, and WN2500.
Router (wifi) --> WNDR3700 (optional) --> WN2500RP -->WNCE3001 -->(TV-Decod)
