clain
May 04, 2012Aspirant
XAVN2001 problem
Hello First of all i would like to say "Hi" to all.As you can see i m new to this forum. So here is my problem.I bought the Powerline Nano200Wifi Set XAVNB2001. Both pieces work fine but i cannot s...
ggift_1029
May 04, 2012Tutor
You might have not installed the Powerline Utility properly. Try to uninstall the utility first and go to the link below depending on the operating system of your computer.
For Windows:
http://support.netgear.com/app/answers/detail/a_id/19401
For Mac:
http://support.netgear.com/app/answers/detail/a_id/19453
Just save the file on your computer and run it. :)
For Windows:
For Mac:
