clain
May 04, 2012Aspirant
XAVN2001 problem
Hello First of all i would like to say "Hi" to all.As you can see i m new to this forum. So here is my problem.I bought the Powerline Nano200Wifi Set XAVNB2001. Both pieces work fine but i cannot s...
clain
Thank you for your answer but i already read this i reinstalled from the support page download i reset both devices i try everything.Something i noticed now is that when i run the utility with the 2101 only it works. When i set security key, the default one, the device seems not to have Internet middle led is off.When there are no security keys devices work but utility stops with runtime error :confused:
