clain
May 04, 2012Aspirant
XAVN2001 problem
Hello First of all i would like to say "Hi" to all.As you can see i m new to this forum. So here is my problem.I bought the Powerline Nano200Wifi Set XAVNB2001. Both pieces work fine but i cannot s...
ggift_1029
May 07, 2012Tutor
If the powerline LED (the middle light) is not on, meaning that it is not finding any compatible powerline adapter that uses the same security or encryption key. You might need to call Netgear tech support to further troubleshoot your concern. Their hotline number is 1-888-638-4327.
