clain
May 04, 2012Aspirant
XAVN2001 problem
Hello First of all i would like to say "Hi" to all.As you can see i m new to this forum. So here is my problem.I bought the Powerline Nano200Wifi Set XAVNB2001. Both pieces work fine but i cannot s...
ggift_1029
May 09, 2012Tutor
clain wrote: Thank you for your answer but is it possible for Netgear to sell a powerline adapters set which are not compatible with each other?? :confused::o
The 2 powerline adapters are actually compatible. What I mean was the XAV2101 might have a different encryption key with the XAVN2001.
You can refer to this manual below:
http://www.downloads.netgear.com/files/XAVN2001_UM_28Jul11.pdf
Check out on Page 6.
