DLCPhoto
Jun 12, 2013Novice
XAVNB2001 Won't Connect to Verizon Galaxy S4
I set up the Netgear Powerline Adapter in my bedroom a year and a half ago, and it has worked perfectly well, without problem at all. I use it to bring WiFi to this part of our house that is far from...
cilonie
Jun 30, 2013Aspirant
DLCPhoto,
Did you try to manually add the Wi-Fi Network of the XAVNB2001 to your S4?
You can also try resetting the XAVNB2001 and reconnect your S4.
