DLCPhoto
Jun 12, 2013Novice
XAVNB2001 Won't Connect to Verizon Galaxy S4
I set up the Netgear Powerline Adapter in my bedroom a year and a half ago, and it has worked perfectly well, without problem at all. I use it to bring WiFi to this part of our house that is far from...
DLCPhoto
Jul 10, 2013Novice
Verizon is now providing an OTA update to the Galaxy S4. Although WiFi fixes are not apparently listed as part of this update, I found that immediately after successfully completing the update that I could now connect properly with the XAVN2001.
I already had this connection on the phone set for a static IP, and this is working fine. I haven't experimented with going back to the original DHCP setting, but wanted to at least report that this was a Verizon quirk with the S4, which apparently is now fixed.
