MarkG87
Apr 05, 2014Aspirant
XE102 Compatability ?
I have 2 XE102's, have had 4, but have lost 2 due to power surges. I need at least 1 more powerline adapter, are the XE102's compatible with any other of the newer models or should I look to just get...
jmizoguchi
Apr 05, 2014Virtuoso
You can NOT use XAV model so you have to use XE models
http://kb.netgear.com/app/answers/detail/a_id/20233
Read all but this is answer you "What is the difference between Home plug V1.0 & Home plug AV?"
