netstar
Aug 24, 2011Aspirant
XE102 connects to each other ... XAV2001's do not ....
Hi All:
I have a XE102 PowerLine that connects to another XE102 ... no problem.
When I replace the two XE102's with two XAV2001's (using the same outlets) ... there is no connection.
I have done factory resets on the XAV2001s and confirm that they work when in the same room.
QUESTION: is it common that the XE102's can connect to each other when the XAV2001's will not for the same set-up environment?
David
David
1 Reply
- netstarAspirantMeant to share that ....
For the remote XAV2001 (that is not connecting), the Power and Ethernet LED's are green. Powerline LED is off (no light).
