heinz57g
May 21, 2013Aspirant
XE104 suddenly halfs throughput
have been using several sets of XE104s at various locations, home, offc, brother, friends - usually and for a long time with good results, and little problems. all providers are 16-20 Mbps max, so ...
jmizoguchi
May 21, 2013Virtuoso
Power line device is sensitive noise in the power line so possible something is happening. Also I can change Mbps rate constantly up/ down so if you are saying you have good throughput for years and likely to be either line noise issues or device start to worn out
