heinz57g
May 21, 2013Aspirant
XE104 suddenly halfs throughput
have been using several sets of XE104s at various locations, home, offc, brother, friends - usually and for a long time with good results, and little problems. all providers are 16-20 Mbps max, so ...
heinz57g
Jun 10, 2013Aspirant
so, checked some more, removing step by step everything that uses electricity in that apartment and on that phase, plus to be on the safe side, the two others.
nothing changed, bad throughput if using sockets more than 5m away.
so it MUST be something else in the house. is there any way to check or measure it? i have no acccess to any of the other apartments.
a big machine of sorts? another POWERLINE operation on the same phase, also NETGEAR or anything else?
any idea?
greetings - heinz -
any idea?
greetings - heinz -
