-Username-
Nov 25, 2020Aspirant
A 7000 wifi adaptor cannot detect 5G network anymore
I've used my wifi adapter to connect to a 5G internet network. At some point, my girlfriend unplugged the cable that was going through the wall to the router and replugged it. Since then my device co...
michaelkenward
Nov 26, 2020Guru - Experienced User
-Username- wrote:
I've used my wifi adapter to connect to a 5G internet network. At some point, my girlfriend unplugged the cable that was going through the wall to the router and replugged it. Since then my device couldn't detect the 5G network, and could only connect to the 2.4G.
Sounds like the problem is with the wifi from the router. Are you sure it is still there?
If it can't see it, then it can't connect. Can anything see the 5 GHz?
No amount of messing around with your USB Adapter will fix broken wifi from the router.
-Username-
Nov 26, 2020Aspirant
Hello,
Yeah all the other devices in my appartment can connect to the 5G. The only one that can't is my desktop computer (which is the device on which the A7000 is connected to).
