kha_grejs
Nov 30, 2020Aspirant
A6100 - WIFI adapter has to be re-installed after is has been closed down
Hej I have that problem that every time I start my desktop I have to reinstall my wifi adapter(A6100 - WIFI USB Mini adapter) and IM pissed about it. So any good Ideas to solve my issue is recommend...
Nov 30, 2020Guru - Experienced User
What device is this connected to?
Is it running windows and what version?
What driver version are you using?
Have you tried installing the stand alone driver and not installing the utility?
kha_grejs
Dec 01, 2020Aspirant
What device is this connected to? desktop Medion Desktop from last year
Is it running windows and what version? win 10 version 2004
What driver version are you using? the standalone and I think its the newest one
Have you tried installing the stand alone driver and not installing the utility? That I do everytime when I start my computer and I have tried to uninstall it also, and then I only install the STANDALONE version
- plemansDec 01, 2020Guru - Experienced User
Medion desktop from last year tells us nothing.
Have you tried it in a different pc/laptop to see if its an issue with your specific pc?
