RAB_2019
Aug 05, 2019Aspirant
A6100 Wifi USB Mini Adapter provides slow receive rate (54 Mbps) in AC wireless mode
On carrying out numerous internet speed tests (Ookla) as well as Command Prompt inquiries such as "netsh wlan show interfaces" and "netsh wlan show wlanreport" I've discovered that my Netgear A6100 W...
Blanca_O
Aug 11, 2019NETGEAR Employee Retired
Hi RAB_2019
Welcome to NETGEAR Community!
May I please know the model number of the router?
Do you have another Wireless device to compare the transmit rate?
Blanca
Community Team
RAB_2019
Aug 11, 2019Aspirant
Hi Blanca,
Thank you for welcoming me and for your response with a query.
My combination modem-router (aka "gateway") is a Hitron model CGN3ACSMR provided to me by Rogers (Canada). I'm not entirely sure what you mean by "another wireless device", but on my other computer (an HP EliteBook 840-G3 equipped with an Intel Dual Band Wireless-AC 8260 wireless adapter) the Receive Rate and Transmit Rate are both 866.7 Mbps when I execute a Command Prompt>netsh wlan show interfaces. The key point here is that the Receive Rate and the Transmit Rate are identical, as one would expect.
Richard
- Blanca_OAug 12, 2019NETGEAR Employee Retired
Hi RAB_2019
Thank you for responding. Please check your modem-router settings and make sure that WMM is enabled.
Blanca
Community Team- RAB_2019Aug 13, 2019Aspirant
Hi Blanca,
Thanks for your note. I've checked the modem-router settings and WMM is indeed enabled.
Richard
