hnwright16
Sep 06, 2021Aspirant
A6100 Wifi USB
I was wondering if there is a way to download the software for this device without the CD or visiting the link with internet. I do not have a CD driver or internet on my PC. I have a gaming computer, ...
michaelkenward
Sep 07, 2021Guru - Experienced User
If you do not have access to a computer, as plemans suggests, you can download the file with anything that has access to the Internet. As long as it doesn't cost an arm and a leg, you can even use a mobile phone. Do it with a phone connected to wifi.
The file says it is 119 MB
Find it here:
A6100 Software Version 1.0.0.36 | Answer | NETGEAR Support
Then you just have to transfer the file to a PC. In my case, I just plug the phone into the PC (USB) and can then copy anything and everything from phone to PC.
A tricksier approach might be to see if you can use your phone as a "modem" to connect your PC to the Internet.
hnwright16
Sep 07, 2021Aspirant
Do you know how to do this on an iPhone. The link is downloaded on my phone, and it’s saved to iCloud. The only things I can see on my Pc are pictures saved on my iPhone, not any documents or downloads.
- michaelkenwardSep 08, 2021Guru - Experienced User
hnwright16 wrote:
Do you know how to do this on an iPhone. The link is downloaded on my phone, and it’s saved to iCloud. The only things I can see on my Pc are pictures saved on my iPhone, not any documents or downloads.I am too mean/poor to pay over-the-top prices for a mobile phone, so I am iPhone ignorant. I also gather that Apple likes to prevent people from taking too much control of their devices, but I am sure that it should be possible to shunt anything you like from a phone to a PC..
In my Android case it is simply a case of plugging the phone into a PC and using software to transfer files and anything else i like between the phone and the PC.
I also have software that lets me transfer things from the phone to a USB/OTG stick that I can then plug into a PC.
You will have to ask an iPhone expert for guidance in how to do that with your phone.
- plemansSep 08, 2021Guru - Experienced User
I'd buy a cheap jump drive. Or borrow one. I'm sure you know someone who has one and an internet connection. I've probably got 10-12 sitting around from educational classes or other things.
https://support.apple.com/guide/iphone/transfer-files-iphone-computer-iphf2d851b9/ios
