Florida3
Jun 29, 2023Aspirant
A6100 Wireless Adapter not Connecting to 5GHz WiFi Router
I have a Netgear Nighthawk AX12 RAX102v2 router. My computer will only pick up 2.4 GHz, and I am having trouble with interference, so I purchased the AC600 WiFi adapter in order to connect over 5.0 G...
Florida3
Jun 30, 2023Aspirant
I am running Windows 10, and all of my drivers are up to date.
Yes, when I run Standalone it does not show the 5.0 GHz in Windows Network and Sharing Center or in the bottom-right of my screen, where the WiFi symbol is.
When I use the non-Standalone this is the message that I receive when I try to connect to the 5.0 GHz. Sometimes it just fails and other times it fails and then hooks up to the 2.4 GHz.
Thank you for responding!
michaelkenward
Jun 30, 2023Guru - Experienced User
Don't forget that with the RAX120 – there is no such thing as the RAX102v2 in your message – unless you have disabled Smart Connect you won't see separate SSIDs for 2.4 and 5.0 GHz. They share the same SSID.
