totooita3
Jun 01, 2024Follower
A6150 - cannot connec to this network
hello, From 2--3 weeks my netgear A6150 ubs2 "cannot connect to this network" on my windows 10 pro pc. after entering the correct pwd running win10 pro 22H2. build 19045.4474 My other devices lapt...
michaelkenward
Jun 04, 2024Guru - Experienced User
What does Windows network wizard say?
Windows likes to protect us from new networks that might be evil. In reality, it often shuts us out of safe networks.
One thought is that you could tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
I'm told that this is rubbish advice. But it has worked for me and others in the same boat.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Adapters - NETGEAR Communities
You might like to search there for messages related to your issue.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
