NicholasTu
Dec 07, 2021Initiate
A6150 Constantly Disconnecting Just after Warranty expired
I Have been having this problem about 2 months after i bought it it will just disconnect on me or the speeds will be awfully low. the warrenty expired 3 months ago and since than it has been steadily...
Dec 07, 2021Guru - Experienced User
did you recently update windows?
I've seen a lot of issues on those series where drivers update and then you have concurrent processes running.
Theres a bunch of posts in the forums or even on youtube for fixes on those series
NicholasTu
Seen those vids they do not apply to me beacuse in them they all Turn off and Disable The Netgear RunSw Service, While I Dont Have any services in my pc That Have Netgear in their name. So i cant use those. All I can Find online is for the 7000s and 6210s, none for my specific adapter.
