Tiako
Dec 08, 2019Aspirant
A6150, installation in MAC OS doesn't work
I followed the procedures from Manual, downloaded software for MAC OS installation and then is asks to restart computer. After i restar, i connect adapter to USB port but the N Icon is not show ins ...
- Jan 13, 2020
Hi mariogaucher
Its has been a while since Apple started phasing out 32bit apps. MacOS Mojave was the last to support 32bit apps. Engineers advised that A6150 will be compatible with macOS Catalina by Q1 2020.
Blanca
Community Team
Tiako
I figured out after some time that the icon appears on the top of the screen, in top bar, and not in the bottom bar. There is also no icon available under apps.
mariogaucher
Dec 17, 2019Aspirant
Hi!
was this intalled on macOS Catalina (10.15)?
I'm looking to buy the same adapter for my old MacBook... and would like to make sure it works in Catalina.
- Blanca_OJan 13, 2020NETGEAR Employee Retired
Hi mariogaucher
Blanca
Community Team
