Marco21
Dec 15, 2019Follower
a6150 linux
Hi all, I am thinking about buying an A6150 wlan-adapter. Is it working (out-of-the-box) under linux (eg. Fedora or Ubuntu) ? Regards Marco
Tom444
Dec 15, 2019Apprentice
In regards to Linux support I would start in the reverse.
Look to see what Adaptors others are using (and Supported) then make your choice.
It really comes down the chipset as Netgear doesn't make their own.
So the 6150 should be a Realtek RTL8812BU
