Maoloi
Dec 05, 2021Aspirant
A6150 malfunction
Sorry for the spelling mistakes in advance. I bought my wifi adapter somewhere last year. i have been using it and it has been perfectly fine and very fast. but i have recently build my new PC, i...
michaelkenward
Dec 06, 2021Guru - Experienced User
Maoloi wrote:
...i have recently build my new PC, installed everything and this time the newest drivers and now it doesnt detect or isn't willing to connect to any other wifi networks then the 2.4 ghz network on this floor.
When building a new PC, it helps to visit the support pages of the motherboard maker and ensure that you have the latest chipset drivers. Windows will not always find these.
You may even have to track down the chip makers and track down their drivers.
Things like USB, audio and LAN chips, may need an update.
We are all used to video drivers, bit these chips are easy to overlook.
- MaoloiDec 06, 2021Aspirant
i have searched for some USB drivers but i cant seem to find them. the thing is also that i have build my PC. used the usb dongle for the first week and it worked perfectly fine and then it just stopped. i dont know if this is a system problem or if the dongle is broken.
does this give another idea of what it could be?
- michaelkenwardDec 06, 2021Guru - Experienced User
Maoloi wrote:
ii dont know if this is a system problem or if the dongle is broken.
Try it on another PC?
What does it look like in Device Manager in Windows?
Wifi adapters
Try removing it from there.
In more than 10 years building PCs, I have never received a motherboard with the latest drivers.
i had a look and this is what it looks like. i also tried it on my laptop. made sure to turn the built in wifi function off, installed the drivers and it worked perfectly. does this give a new idea?
and what i meant with the USB drivers was i didnt find specific drivers for only the USB ports. i have installed the requered drivers.
