Maoloi
Dec 05, 2021Aspirant
A6150 malfunction
Sorry for the spelling mistakes in advance. I bought my wifi adapter somewhere last year. i have been using it and it has been perfectly fine and very fast. but i have recently build my new PC, i...
Maoloi
Dec 06, 2021Aspirant
i have searched for some USB drivers but i cant seem to find them. the thing is also that i have build my PC. used the usb dongle for the first week and it worked perfectly fine and then it just stopped. i dont know if this is a system problem or if the dongle is broken.
does this give another idea of what it could be?
michaelkenward
Dec 06, 2021Guru - Experienced User
Maoloi wrote:
ii dont know if this is a system problem or if the dongle is broken.
Try it on another PC?
What does it look like in Device Manager in Windows?
Wifi adapters
Try removing it from there.
In more than 10 years building PCs, I have never received a motherboard with the latest drivers.
- MaoloiDec 06, 2021Aspirant
i had a look and this is what it looks like. i also tried it on my laptop. made sure to turn the built in wifi function off, installed the drivers and it worked perfectly. does this give a new idea?
and what i meant with the USB drivers was i didnt find specific drivers for only the USB ports. i have installed the requered drivers.
- michaelkenwardDec 06, 2021Guru - Experienced User
Suggests that it is a Windows problem.
That's not what I meant.
Before your PC can run a Windows it has to install a whole raft of drivers for the basic functions., those supported by the chips on the motherboard.
When you buy a motherboard it usually comes with a CD stuffed with all those drivers. By the time the CD gets to you, there's a good chance that there are newer versions.
First start with the motherboard maker, then look at places like Intel, Realtek and so on. Intel is famous for its wifi drivers, but they won't involve your Netgear device.
if its probably a windows problem, would the drivers still help or would something else help? or would it be wiser to go cable?
