Cam22
Jul 17, 2022Tutor
A6200 - 802.11ac WiFi USB Adapter - Dual Ba - I have started to receive a runtime error
I had a windows 10 update in the last few days. But only received the attached message today. Any solutions?
- Jul 17, 2022
Have you tried uninstalling the program and driver and then reinstalling?
Jul 17, 2022Guru - Experienced User
FlyByGal
Jul 19, 2022Aspirant
I am on Windows 11 on a newer pc.
I have this same issue now, daily (or at each login if more than one login daily). Noting it only started for me roughly 3 days ago also.
This pops up in a tiny window center of my (dual) primary monitor, at every start-up at the point that it (seems) I have loaded all to a passive desktop. It asks me to click [OK] and when I do, I do not lose my WIFI internet, not even a hiccup in speed. For 12+ hours a day.
I run Netgear Genie and I can reproduce this pop-up randomly throughout the day by (re) opening Netgear Genie (Version 1.0.0.35) and choosing Other > Software Update: [Check] button. So I suspect that Netgear Genie is auto-checking for an update at boot-up and triggering the error.
Pop-up:
Microsoft Visual C++ Runtime LibraryProgram: C:\Program Files [x84)\NETGEAR\A6200\A6200.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
This lead me to look to see if Netgear Genie had an update, and I found out no more updates are coming. There is a replacement app, and if my gear isn't supported, then I can still use the Netgear Genie. My A6200 is not supported by the new app.
https://kb.netgear.com/000060889/Notice-NETGEAR-Genie-App-Will-No-Longer-Be-Updated
I may be able to keep using Netgear Genie per the notice. But there is no way to turn off that auto-check for updates at boot. Therefore, if it is the checking for updates causing the error, I guess I better get used to seeing and closing the error pop-up at login. But Netgear Genie's seems to always connect me fully to my network first, and then checks for updates > errors/closes.
And if this notice was posted April 2019, then wow two+ years later I feel fortunate I guess it has not errored out until now.
Given what the app manages, it is unclear if its not being updated (and no replacement app available) and my still using it with the A6200 exposes me to a degree of security risk as every day (of the past 2+ years and future) passes? My A6200 will not connect to my network without Netgear Genie running and connecting it. If a security risk, and I require it to connect the A6200 to my Wifi, then it feels like as far back as April 2019 I should have somehow known to buy another Wifi Adapter? Until three days ago, I have run this app and it has checked for updates without error. I now wish it had triggered April 2019, so I could have decided if I felt at more risk back then.
Sharing only. Wishing all well!
