Wolstan_Dixie
Feb 04, 2022Aspirant
A6200 wifi adapter needs uninstalling and reinstalling
Windows 7 64 bit I have a A6200. I am getting it auto-disabling and the odd blue screen. I would like to uninstaal it and reinstall with a new copy of the software, just in case it has become ...
Feb 04, 2022Guru - Experienced User
Yes, you should be able to use that.
- michaelkenwardFeb 05, 2022Guru - Experienced User
Whether or not it is a good idea to have anything on Windows 7 is a different matter.
There are, of course, older versions of the drivers in the library.
- Wolstan_DixieFeb 05, 2022Aspirant
Thanks a lot - I see that earlier releases are there, perhaps it would be better to use the one at or just after the one I have installed
