ckg009
Mar 18, 2017Aspirant
A6210 BSOD on Windows10 after v35 SW Upgrade
After the v35 driver install, I've been getting a lot of BSOD. Not long after a reset, the computer would freeze with a stated cause of BAD_POOL_HEADER. After searching, I wasn't aware I had even...
- Mar 30, 2017
Hi All,
Uninstall the driver of the A6210. If you happen to know how clean the registry of your computer, try to clean it. You can use the latest driver to install the device.
https://kb.netgear.com/000037991/A6210-Software-Version-1-0-0-36
updatedrivers
I've solved my issues with my A6210 and new Windows 10 install by updating drivers for the Intel(R) Management Engine Interface and Intel(R) Chipset Family SMBus Host Controller - 8CA2. Have you made sure all of your motherboard chipset drivers are up to date?
- ckg009Mar 20, 2017Aspirant
Just checked and my Intel drivers are up-to-date.
