ckg009
Mar 18, 2017Aspirant
A6210 BSOD on Windows10 after v35 SW Upgrade
After the v35 driver install, I've been getting a lot of BSOD. Not long after a reset, the computer would freeze with a stated cause of BAD_POOL_HEADER. After searching, I wasn't aware I had even...
- Mar 30, 2017
Hi All,
Uninstall the driver of the A6210. If you happen to know how clean the registry of your computer, try to clean it. You can use the latest driver to install the device.
https://kb.netgear.com/000037991/A6210-Software-Version-1-0-0-36
pschenck
Mar 23, 2017Aspirant
Dealing with exactly the same issue. Windows 10, webroot, malewarebytes. Besides all driver updates, also tried removing all anti-virus software, disabling onboard wireless and NIC. Tried a new clean install, no BSOD until A6210 driver installed. What USB WiFi stick did you go with?
- ckg009Mar 23, 2017Aspirant
Starts with an L****. And what's really aggrivating, though it's new and their high-end USB Adapter, it's just not as fast nor as steady with the connection. Throughput was much better with the A6210.
Can't wait for either a fix from NetGear or L*** to come up with their new USB Adapter.
- JamesGLMar 30, 2017NETGEAR Employee Retired
Hi All,
- JamesGLApr 03, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
