r3v0Lut10n
Jun 01, 2020Aspirant
A6210 disconnect , replug helps only
So before buying something else which I can use, I give it a try here. Installed the latest driver (1.0.0.39), step by step as written on here. When I bought it, and since then have the same ...
- Jun 02, 2020
As I don't expect a response here, spend some time on searching.
So this wifi adapter is using mediatek MT7612U chipset. Clean everything (disconnect and remove netgear driver) and then install the below. So far (4 hours) it's working, and they should either use this driver or give any sort of support. Next one (this was my 3rd netgear stuff (1 router and 2 wifi adapter)) will be definately from another brand.
https://www.mediatek.com/products/broadbandWifi/mt7612u
Hope it will help you or anyone who is searching for a solution.
dlaw007
Jun 02, 2020Aspirant
I have the exact same issue.
I noticed it happens both randomly and on resume when my machine has been asleep.
- r3v0Lut10nJun 02, 2020Aspirant
