lod1995luke
Mar 27, 2021Follower
A6210 disconnecting everytime I try to game or upload or download
So this has been going on for months, Everytime I put a small bit of pressure on the netgear ac6210 it disconnects and forget about trying to use my 5G as it just connects for 4-5 seconds and disconn...
michaelkenward
Mar 28, 2021Guru - Experienced User
lod1995luke wrote:
So this has been going on for months, Everytime I put a small bit of pressure on the netgear ac6210 it disconnects and forget about trying to use my 5G as it just connects for 4-5 seconds and disconnects again.
If this is physical pressure – hard to tell from your description – it could be a design problem with your unnamed PC.
Is the A6210 plugged into the USB port? Tried a different USB port? How about a short extension cable?
lod1995luke wrote:
This product is worse than the chinese one it replaced!
Different shape and size?
If you are talking about something else, I would look for updated USB drivers from whoever made your PC. These will not show up in Windows updates.
I assume that you have already looked for help from the PC maker. As the saying goes, it takes two to tango.
