Indecl
Jun 09, 2021Aspirant
A6210 Disconnects/Freezes with 40-50% Network usage
I have just returned home from a 6 month stay overseas. After turning my PC back on and letting windows do it's forced updates, I am now having an issue where the Network will drop and reconnect itself. At first I thought it was my USB drivers, because I could hear the disconnect and reconnect sound when it did so. None of my other devices were disconnecting during this issue, and reinstalling them did not solve my problem.
Then I proceeded to make sure my Genie and Wireless adapter firmware was up to date, which it now is. The problem still persists. I also used the standard answer to these problems and disabled all power saving options from the USB's and well as the Wireless adapter as explained here; https://kb.netgear.com/23352/A6200-A6210-WNDA3100v2-wireless-adapter-intermittently-disconnects
While trying to figure out what is happening, I noticed that if I were to initiate a task that would bump my Network usage to 40%+ on my Task Manager, I would suddenly lose any ability to do anything related to the internet. Chrome won't load, videos won't play, games won't load, Discord will get a 5000+ ping. Achieving that threshold happened with a task as simple as installing a game from steam, nothing else. As soon as that task was done, if it didn't straight up disconnect me from the network before finishing, everything would return to normal operation. Reinstalling Borderlands 3 took almost a full day, with 9 instances of disconnecting while attempting to do so.
I will also note that I have the same model adapter on a second PC, and although I have not gone this far into diagnosing with it, it has the same issue of randomly disconnecting itself only that one does not see to like reconnecting automatically. My main PC, where I have noticed the things above, has about a 50/50 shot of reconnecting itself or I have to unplug and replug in the adapter to get my network back.
I've also checked my modem/router as it's a C7100V and everything seems to be up to date and functioning normally. When I have this issue, I am able to access my phones wifi like normal so it's exclusively these PC's and this adapter. What in the world is going on?
try this.
Open your services menu
Find NetgearSwitchUSB or RunSwUSB
Right click and click Stop
Right click and select Properties
Under Startup Type select Disabled
This service won't be on next time you start your computer
- IndeclAspirant
Ok, I have switched it to disabled, what purpose might this serve?
sometimes you see it get stuck or 2 services running at the same time. thats when you see that spike in usage.
did you install the stand-alone driver or the utliity?
I've also seen some have better luck with the stand alone driver.
